Need help with biasing a common emitter amplifier
Discussion in 'The Projects Forum' started by EarlAnderson, Jun 1, 2012.
  1. EarlAnderson
    Nov 13, 2011
    166
    I am trying to build a common emitter amplifier as a preamp stage to a class AB output amplifier which I plan to use to drive a couple of speakers, but I'm having a little trouble trying to figure out the right resistor values to use to bias it. I've turned to the Internet for help, with no luck so far. It would be much appreciated if someone could help me with choosing the right resistor values to use. Thanks :)
  2. KJ6EAD
    Apr 30, 2011
    1,426
    363
  3. #12
    Nov 30, 2010
    16,685
    7,322
    Would you settle for a low noise jfet preamp?
  4. EarlAnderson
    Nov 13, 2011
    166
    I would use that but I don't have any spare jfets lying around so I was thinking about using a 2N3904
  5. #12
    Nov 30, 2010
    16,685
    7,322
    If you run into noise problems, the jfet is good at fixing that.
    It all depends on exactly what levels of signal you are trying to pre-amp.
    Good calculating.
