I am new to this forum but have tried to find what I am looking for with minimal success. I have a pair of LED tail lamps from an Infiniti FX45. When I first picked them up I was a bit surprised to see only two leads connected to the assembly's LED panel. I was expecting to find at least three: one for the running light, one for the brake, and the third for the ground. I hooked up a 12 volt source to the LED lamp and everything works perfectly. However, now I have no clue how to have these lamps work properly for both the brake and tail light functionality that I need. When I hook the lamps up to the 12 volt source the LEDs emit their maximum output... I am assuming that the Infiniti has a very complex system that varies the current/voltage in the wire to the lamp so that it functions properly. The vehicle that these will be modified to fit is a typical incandescent configuration with running and brake lights on the same bulb. So my question is the following: how do I wire these lamps appropriately so that I have two distinct phases; one for the tail lamp and one for the brake lamp? I would be extremely grateful for any and all feedback, suggestions, and/or information...
Thanks!
Thanks!
