How do I calculate the peak to peak voltage required across the 8 ohm resistor (R9) to get a 3 W output? I've attached the circuit and would appreciate any help with this circuit.
Is the 3W continuous power or peak power?How do I calculate the peak to peak voltage required across the 8 ohm resistor (R9) to get a 3 W output? I've attached the circuit and would appreciate any help with this circuit.
by Duane Benson
by Jake Hertz
by Duane Benson
by Jake Hertz
