Need Help With an Design
Discussion in 'The Projects Forum' started by eyik66, Dec 15, 2012.
Thread Status:
Not open for further replies.
  1. eyik66
    Dec 15, 2012
    30
    I am working on a project that needs to do the following:
    1. Read serial data that is being sent by a device, store the values, change two of the values, and then send the revised data to a different device.
    2. It may be necessary for the device to output at a faster rate than the input (output 5 times for every 1 time the serial input is received). The values that are being changed in step 1 are from a device that has a rapidly changing value. It is ok if the other values are not refreshed and are older than the revised values.
    Can someone point me in the right direction on what type of circuit would be capable of achieving this?
    Also, I need to start "seeing" the data being sent with the device. How does one "intercept" the serial data and start sorting and manipulating it? I have been reading about a "sniffer" program. Am I on the right track?
    Thanks for the help!
  2. eyik66
    Dec 15, 2012
    30
    also, the serial data is J1850 Protocol if that helps. Thanks again
  3. panic mode
    Oct 10, 2011
    1,328
    305
    this is automotive topic and as such may be closed by moderator (see site terms)
  4. eyik66
    Dec 15, 2012
    30
    crap didn't know that. Honestly, I don't need high resolution information. I am really just looking for very general information on the type of components that need to be utilized to receive serial data, re-write values and then transmit them. The exact sequence of the serial isn't very important to me right now
    I'm really just trying to understand what kind of circuit/chips are needed to achieve this:
    1. Receive and store serial data
    2. Receive data from a sensor, and write the data into a specific serial block
    3. Send the serial data out
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    I am closing this thread as it violates AAC policy and/or safety issues.
    Quote:
    6. Restricted topics. The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
    There will be enough sites where automotive questions can be discussed :
    Member selected automotive forums
    Bertus
Thread Status:
