Need Help with Amp
Discussion in 'General Electronics Chat' started by dexterdoo, Jan 31, 2014.
  1. dexterdoo
    Jan 31, 2014
    6
    I have a turntable head-amp that I've had for about 30 years and it recently died. I've attached a copy of the schematic diagram for it and the thing is so simple 'til I cannot believe I haven't been able to repair it??? I've checked the parts and found nothing bad and when the unit receives power from the 9 volt battery, all of the transistors seem to have the correct bias voltage on them, but still there's no audio out (checked with my O-scope)! I don't get it??? I'm wondering if someone could point me in the right direction in terms of repairing this amp? Thanks!
  2. ErnieM
    Apr 24, 2011
    7,434
    1,625
    If I have DC (the bias) but no AC (the music) I'd start looking at the caps. 30 years is several cap lifetimes, and one or more may now be open.
    Shorted caps have the same voltage on both leads, but so do caps not blocking DC so it takes some skull sweat.
    Open caps are a breeze to check: just put another cap in parallel and see if musical excellence returns.
  3. bountyhunter
    Sep 7, 2009
    2,498
    507
    You sure that schematic is complete? I don't see how it can work as a turntable amp.
    #12 likes this.
  4. KL7AJ
    Nov 4, 2008
    2,043
    292
    I don't see how it can work as ANY kind of amp! There is no load resistor on the transistors at all! At first it looks like a push pull grounded base configuration....but the collectors are shorted together!
    Weird.
    Eric
  5. Dave_UYZ
    Jan 16, 2014
    29
    Lets face it, it's mostly a filter of known slope, rather than a straight Amp (look at the strange values of R). It's an Emitter Follower of sorts, so there's not a lot of gain in it.
    I agree with the "check the caps" suggestion.
  6. Jony130
    Feb 17, 2009
    3,990
    1,115
    Collector are short only for AC signal. And If you drawn the small signal equivalent circuit You will see two common base amplifier connect in parallel.
    Also notice that the 9V battery work as a floating power supply.
    http://users.ece.gatech.edu/~mleach/headamp/
  7. crutschow
    Mar 14, 2008
    13,471
    3,359
    Yes it is a common-base push-pull amp as KL7AJ and Jony noted, likely to amplify the small output from a moving-coil cartridge. It looks a little strange since it depends upon the floating 9V battery power supply for proper operation. I'm still scratching my head a little trying to follow how it works. R7 is the AC output load for the two collectors.
    I simulated an AC gain of about 43 with R7 = 3.9kΩ.
    The only frequency roll-off caps are C1 and C2 which give a corner frequency of about 3MHz. All the others are just filter or coupling caps.
    As others have noted, I expect one of the (likely electrolytic) caps has gone bad in your amp. Try following the signal from the input to the output with your oscilloscope.
  8. dexterdoo
    Jan 31, 2014
    6
    Yes, the amp is for my moving coil cartridge and I'm pretty sure that is the correct schematic. Obviously it's only showing one of the channels. I suspected the caps also. I checked every one with my DVM (don't have an actual capacitor checker) and didn't notice anything suspicious although I may've missed it? I'll go back and check them again. The DVM should be ok to test them, right?
    What a cool forum! Found it out of desperation after spending waaay more time on this project then I intended to. I'll feel like a dork if I have to find someone to repair this for me but I'm gonna give it one more shot. I'll post back and thanks again guys! :)
  9. crutschow
    Mar 14, 2008
    13,471
    3,359
    The DVM will check that the cap is not shorted but won't check if it's open.
    Are both channels bad?
  10. #12
    Nov 30, 2010
    16,663
    7,306
    +1 on the head scratching!
    Never seen such an animal before.
    If anyone wants to elaborate on how it works, I'll be watching.
  11. dexterdoo
    Jan 31, 2014
    6
    @ crutschow
    Yes, voltage all over the place but nothing from either channel. Won't checking out of the PCB for opens work?
    @ #12
    Not so sure about this schmatic now because there are actually (10) 220uf caps on top of the board and (9) on the bottom which doesn't exactly square with the diagram even if you double the amount to allow for the other channel. The "final Inspection" tag inside the unit is dated 7-21-80! That being the case I think I will change all 19 of the caps and see where that gets me. I've already ordered them.
  12. #12
    Nov 30, 2010
    16,663
    7,306
    Probably a smart thing to do. Forget the head scratching and shotgun it. :D
  13. dexterdoo
    Jan 31, 2014
    6
    I agree ... LOL!!! :D
  14. Jony130
    Feb 17, 2009
    3,990
    1,115
    Here you can read from original designer how this circuit work
    And simply draw a small signal model and you will see how this circuit work.
    So you never see a amplifier with a floating power supply?
    http://en.wikipedia.org/wiki/Circlotron
    See also QSC amps,Peavey amps and Yamaha A-S1000; A-S2000; A-S3000
    #12 likes this.
  15. #12
    Nov 30, 2010
    16,663
    7,306
    Yes. We did some a few weeks ago with a model number something like 700A or M700. I just can't see how to drive the emitters of a push pull stage to get a voltage gain.
    I learn something almost every day on this site.
    Edit: OK. That helped. Thanks for the link.
  16. crutschow
    Mar 14, 2008
    13,471
    3,359
    In a common base amplifier the AC collector current is essentially the same as the emitter current generated by the input source voltage (differing only by the base current). The voltage gain is derived from the collector resistance load being much larger than the equivalent emitter resistance.
    In the subject amp, when one transistor emitter/collector current increases from the signal voltage, the other emitter/collector current decreases. The two AC currents are opposite polarity thus they add at the output load (through the output caps C9 through C12), since the collector resistance of each transistor is much higher than the output impedance. This summed current flowing through the output load R7 generates the voltage gain. The gain value is thus proportional to the value of R7.
    #12 likes this.
  17. Gones
    Feb 1, 2014
    What is Amp. what does it mean. maybe it is related with electronic device. if this is then i wanna told you on thing that is e cigarette. this is also a electronic device. hope we can discuss with this later.
  18. redplaya
    Member
    Jan 26, 2014
    30
    I agree with everything CRUTSCHOW said. The industry standard for lifetime on electrolytic was 10yrs where I was, so with that said who knows what complex impedance they are now. After that check the BJTs but it unlikely anything's wrong. After that, throw it away.
  19. crutschow
    Mar 14, 2008
    13,471
    3,359
    The is off-topic and hijacking of this thread. Please start a new thread with your questions.
  20. R!f@@
    Apr 2, 2009
    8,785
    771
    What hell is Gones talking about?
    I was reading through and that guy threw me off the topic.
    To the OP. Try replacing all the electrolytic. That is what I would do first
