I have a circuit that interfaces to the analog input of a PIC16F687. It then drives 6 LED based on the current and then send it serially to be saved in a file.
The circuit works fine on a resistive AC Load but when used with a 120V 1.5HP universal motor the reading is lower than what is expected. The circuit, due to cost does not have a lot of filtering other than the AC output of the ACS712 to a DC voltage.
This is my first time using a hall effect type sensor and not sure if it is picking up the magnetic field of the motor. The circuit board sits on top of the motor housing.
Any suggestions would be appreciated.
David
David
