Need help with a relay
Discussion in 'The Projects Forum' started by Falven, Feb 27, 2010.
  1. Falven
    Feb 27, 2010
    15
    Hey guys,
    So I bought a 12vdc coil relay by accident, when in fact i need a 4-5vdc relay to use with my arduino ( arduino.cc ), is there any way I could make this work?
    Thanks,
    -Falven
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If you have a 12v supply available in your application, you could switch the ground side of the coil with an N-ch logic-level MOSFET or an NPN transistor, with a 470 Ohm resistor on the base.
    Make sure to use a diode across the relay coil, or the coil current (reverse EMF) will blast the MOSFET/transistor when the Arduino shuts it off. The cathode of the diode (banded end) goes towards +12v. Any 1N400x series diode should work fine.
  3. Falven
    Feb 27, 2010
    15
    Thanks a ton, trying this now, will post back :)
