Need help with a pcb board
Discussion in 'The Projects Forum' started by greenJames, May 17, 2013.
  1. greenJames
    Apr 24, 2013
    68
    Ok I have down loaded eagle v6
    I been working on it (the program) for a week went my son came across a project he wants to make over the summer holidays.
    He has even found a web site with free drawing in eagle now I have down loaded his files and opened them in eagle and to my surprise I can't use them two many layers but then I opened the board area and to my surprise it opened
    So I loaded a pcb to gcode program and started the process of putting in my information ie mach3 etc but when I came to run the program eagle didn't like it and refused to write the gcode saying is and that file not found arrg
    I don't really know what I've done wrong but maybe the version 6 lite has limits
    All the file have been made in eagle v5 would some one kindly convert the files for me as I'm at a loss
    This is the web site address
    http://www.hownottoengineer.com/down.html
    he also has the library files as well to down load would any one be so kind as to help me please
    Green James
  2. ErnieM
    Apr 24, 2011
    7,442
    1,628
    Well... each layout program uses its own proprietary format, and there's really no need for a translator: if you want a file in X you make it in X.
    There's some common formats in netlist, which is the go between the schematic and the PCB, and the standard output for PCB fabrication is a gerber file, and the all make that.
    That sight does seem to include a download of the gerbers. Just be advised multilayer PCB's ain't exactly cheap. Not a huge strain of you get them made in China, which I do all the time thru EBay.
  3. apprenticemart2
    Member
    May 7, 2013
    67
    7
    What are you trying to do?
    Machine the board yourself using a CNC milling machine?
    Etch it yourself?
    Did you download the ST Microelectronics Eagle Library?
  4. greenJames
    Apr 24, 2013
    68
    not yet I'm trying to do this at the moment but I can't work out how to import it
    I did say I was green
    James
  5. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Some of the traces are awfully close together, and the drill sizes are tiny according to my DRC. Just make sure your manufacturer can handle it.
    Are you just trying to get the designs from it (i.e. gerber files)?
  6. greenJames
    Apr 24, 2013
    68
    i manage to run a small test on this board and even a 10 degrees engraving bit struggled with the cutting so I'm going to redesign it from scratch
    james
