Need Help with a INA Amplif
Discussion in 'General Electronics Chat' started by Giovanni, May 20, 2008.
Thread Status:
Not open for further replies.
  1. Giovanni
    May 20, 2008
    Hi everybody, i'm new on this forum; i'm in need of help using an INA 52063. I use it as a 2nd stadium after a transimpedance amplifier and the problem is that when i turn on the DC generator the amplifier heats up and breaks .
    The layout used is the same shown in the application notes of the datasheet, and the supply is +5V. I've also added a 50 ohm parallel resistor at the output for impedance matching.
    Thanks for the help^^
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    What is your input signal level?
    What is the thickness of your PCB?
    If you're up in the GHz region, you'll have to plan your PCB traces pretty carefully to get a good impedance match.
  3. Giovanni
    May 20, 2008
    For my application i need to work around 20/30 Mhz so i use a 20 MHz 100mVpp input signal for testing. Do you think it could be a matching problem?
    My PCB is a double sided approx 1.5 mm thick...
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    100mV pp? :eek: That's what's killing it.
    Absolute maximum input power is +13 dBm, or 4,467 uV.
    You're feeding it 40 dBm, or 100,000uV.
  5. Giovanni
    May 20, 2008
    How do you obtained these values? I thought +13dBm was equal to 1V ( 10^(13/10) => approx 20 mW so V=sqrt(20mW*50ohm) => approx 1V)
    However i've noticed that even if i don't give a singnal in input, when i supply the IC it burns out even at +4V... help! :(
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Can you post the layout of your printed circuit board and indicate the component values? The schematic would be helpful as well.
    The chip burning with no signal makes it likely that it is going into a destructive oscillation, possibly due to layout or wrong value components.
  7. JoeJester
    Apr 26, 2005
    3,403
    1,230
    dBm is referenced to 1 milliwat. 100,000 uV is neg 7 dBm (-6.9897).
  8. Giovanni
    May 20, 2008
    Non-productive comment removed.
  9. hgmjr
    Jan 28, 2005
    9,030
    214
  10. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    146
    Some people in life speak foreign languages; for everyone else there's Babel Fish.
    Dave
Thread Status:
