Need help with a diode circuit problem
Discussion in 'Homework Help' started by copper_pipe, Sep 30, 2014.
  1. copper_pipe
    Sep 30, 2014
    7
  2. paulktreg
    Distinguished Member
    Jun 2, 2008
    623
    124
    Homework?
    (Show us a screenshot of your attempted solution).
    dhakal_aman likes this.
  3. copper_pipe
    Sep 30, 2014
    7
  4. Jony130
    Feb 17, 2009
    3,991
    1,115
    Hi, to me your solution is wrong .
    For Vd = 0.7V diode current is equal to
    Id = (4*0.7V + 5*0.7^2) = 2.8 + 2.45 = 5.25mA
    And resistor current
    Ir = (5V - 0.7V)/200Ω = 21.5mA
    So Id is not equal to Ir. and this means that your solution is wrong.
    And the correct answer is Vd ≈ 1.51V because this time
    Id ≈ 4*1.51V + 5*1.51V^2 ≈ 17.4405mA and Ir = (5V - 1.51V)/200Ω ≈ 17.45mA
    And since Id≈Ir we have a correct solution.
    Additional I plot Id vs Vd and load line
  5. copper_pipe
    Sep 30, 2014
    7
    where is the 1.51v coming from?
  6. Jony130
    Feb 17, 2009
    3,991
    1,115
  7. MikeML
    Oct 2, 2009
    5,451
    1,066
    Or Let LTSpice solve that equation. The B1 behavioral current source has the same I/V behavior as the diode...
    Jony130 likes this.
  8. copper_pipe
    Sep 30, 2014
    7
  9. Jony130
    Feb 17, 2009
    3,991
    1,115
  10. copper_pipe
    Sep 30, 2014
    7
    230 V * 1/5 = 46Vrms on the secondary
    Output pk voltage will be 46 * sqrt(2)/pi = 20.70V = DC
    RMS = 20.70V/2= 10.35V
    P = I^2 * R = Vrms^2/R
    P = 10.35^2/10 = 10.71W
    Does this look correct to you guys?
