Need Help with a Deep-Discharge Circuit !
Discussion in 'General Electronics Chat' started by offtherails2010, Jan 14, 2012.
  1. offtherails2010
    Dec 31, 2011
    Hello & Good day to everyone!
    I have put together a 'power-pack' from four 3.6v 18650 batteries having 14.4v in total... (in series at the moment, can change if needed...)
    I'm pretty new to electronics and have a few basic skills with soldering etc, what i am trying to make is a Circuit that stops my power-pack from deep discharge but to make it as simple as possible...
    Found this circuit below:
    (credit to D.Mohankumar!)
    But i need to augment the circuit to allow for 14.4v battery pack, How do i do this & where do i start ? (what equations do i need here :confused:) I am learning as i go but the only way i learn is to kinda immerse myself in the deep-end!
    Eventually i need the power-pack to emit 8v and no more than 200mA, would i be able to incorporate both circuits in one ? (Deep-Discharge Preventative circuit + voltage drop circuit) ???
    I have the following:
    - medium selection of voltage regulator semiconductors
    - selection of resistors
    - selection of capacitors (ceramic & electrolytic only)
    - selection of transistors (NPN & PNP)
    - Four 18650 type 3.6v batteries
    - Breadboard
    - A Fast-Study-Mind ! (lol)
    Please could anyone help me get closer to finishing off this project ?
    A Great Many many thanks in advance for any/all help received !
  2. k7elp60
    Nov 4, 2008
    I'm not sure that I fully understand what you wish to do. If the battery has a 14.4 voltage at full charge, do you wish to stop the discharge when the voltage drops to 8V? Do you also wish to limit the discharge current to 200mA?
  3. Smoke_Maker
    Sep 24, 2007
  4. Smoke_Maker
    Sep 24, 2007
