Need help with a circuit!
Discussion in 'General Electronics Chat' started by spleenharvester, Mar 16, 2013.
  1. spleenharvester
    Mar 16, 2013
    Hey all. Sorry if this is the wrong section but I'm not sure where to put it!!
    This is part of a HP 6735s motherboard.
    VADP reads in at 19v like it should.
    I can't find R1302 yet to test +3v.
    Basically, ADP_EN# should be reading in at a very low voltage. But it reads in at 19v, instead. Because of this, the laptop stays dead unless ADP_EN# is shorted to ground.
    The positive leg of D1010 reads as 8v.
    ADP_EN (not ADP_EN#) seems to be reading at 0v, I will double check this later. It may be correct for all I know.
    Anyone got any ideas as to why the voltage is staying at 19v?
    Cheers! :)
  2. antonv
    Member
    Nov 27, 2012
    149
    27
    U1024-B is a comparator. Are the voltages around it making sense? Like, is pin 6 at a lower voltage than pin 5?
  3. spleenharvester
    Mar 16, 2013
    It sure seems to be. I think I found the problem - LIMITsignal is reading at 0v and comes straight from the DC jack. Could my adapter be causing it? :(
