need help with a 4bit combination lock system
Papabravo
Joined Feb 24, 2006
21,228
You need something that counts the three attempts. This could be an
  1. Up Counter that goes "0-1-2-3"
  2. Down Counter that goes "3-2-1-0"
  3. A shift register that shifts 1's at the right that goes "000, 001, 011, 111"
  4. A shift register that shifts 0's that goes "111, 110, 100, 000"
And many other variations on that theme.
matthew26
Joined Feb 21, 2011
6
any way could get you to show me how to put the shift register into the circuit?
spinnaker
Joined Oct 29, 2009
7,830
Why not just use a microcontroller? You would have to learn programming but that is not too difficult. It would make the job so much easier and open up a whole bunch of options.
matthew26
Joined Feb 21, 2011
6
Why don't you show me how you think it should go and I'll tell you if I think it will work
View attachment 4bit drawing.pdf
if i split the 2 grounds from the red and green LED's and put the red LED into the D flip flops and ran it back into the circuit. after the 3 attemps of (high's) 1 going into the D flip flops would it then lock out until it was reset?
sry for the bad drawing it wouldnt let me edit the original picture i got from this site
Papabravo
Joined Feb 24, 2006
21,228
Your "Go/No Go" signal should be used to derive the clock. The data_in for the first stage should be set to zero or one and then you need to decode three identical outputs of all zeros or all ones depending on the data in choice.
Last you need a way to RESET the shift register
matthew26
Joined Feb 21, 2011
6
last question
what would be the best way to reset the shift register?
I need a hint cause I really have no clue or i would do it myself
Papabravo
Joined Feb 24, 2006
21,228
That is a really good question. From a logic standpoint another switch would do the job. From a security standpoint you would have to think about where to put it, how to access it, and how to activate it.
matthew26
Joined Feb 21, 2011
6
couldnt i just put the "go" through to the clear? and reset it when the right combo is used? then after the power went off the D flip flop would just reset itself? because its suposed to lock up and not work after 3 attempts
