Need help with 555 circuit
Discussion in 'The Projects Forum' started by gunlocators, Dec 19, 2014.
  1. gunlocators
    Dec 4, 2014
    12
    I have some 555 ICs and need to find a schematic for a circuit that will be on for 5 minutes and off for 5 minutes. Actually between 3-5 minutes is fine however the amount of time circuit is on should be very close if not the same as time off.
    this will run a relay on and off I have the relay and the 555 probably most if not all the other components however when I google 5 minute circuit I did not find anything using a 555 IC any help is appreciated.
  2. #12
    Nov 30, 2010
    16,661
    7,305
  3. KJ6EAD
    Apr 30, 2011
    1,426
    363
  4. MikeML
    Oct 2, 2009
    5,450
    1,066
    300sec is getting close to the upper limit for a 555. The R needs to be ~1meg, which can only supply about 2uA at the 555's trip point. C needs to be an electrolytic capacitor whose leakage is approaching 2 uA, so you get erratic or unreliable timing.
    I second the recommendation of using the CD4060.
  5. #12
    Nov 30, 2010
    16,661
    7,305
    Thanks, KJ6. I'm glad I didn't spend any time designing what he already has!
  6. gunlocators
    Dec 4, 2014
    12
    So I have the schematic downloaded from Kris. However what if I do 180 seconds will the 555 be ok. I have some flexibilty on the time off and on I just need them to be close to the same time on as it is off. That too does not have to be exact but somewhere close would be nice. If thats possible I would rather go that route for now and get the project going while I order the CD4060 and wait for it to arrive.
  7. Alec_t
    Sep 17, 2013
    5,956
    1,132
    Anything beyond ~ 1min is dodgy with a 555 because of capacitor leakage (as Mike mentioned). If you are concerned about the on and off times being stable and as equal as possible you really should abandon the idea of using a 555.
  8. gunlocators
    Dec 4, 2014
    12
    Well Here is what I did with 9volts in to the 555 if it does not last then I will go the CD4060 route. I ran the circuit for 2 hours and it seemed to cycle fine for now. Thank you for all the help. I wanted to try this seeing for now I had all the components on hand....
  9. Bernard
    Aug 7, 2008
    4,232
    414
    Do'nt forget to connect pin 4 to + supply, and add supressor diode across relay coil, cathode to + V side.
    Longest time period that I have used a 555 was 3 hours. 30 min, no sweat.
