need help with 360w,86v circuit for ENX lamp
Discussion in 'The Projects Forum' started by androsboy, Jan 25, 2007.
  1. androsboy
    Jan 25, 2007
    HI all
    am repairing an overhead projector the circuit has a diode rectifier that is bad, it breaks down the 120V to 86V @360W but i cant find a replacement. any alternative ideas would be very helpful.
    thanks!!
  2. MVIBoss
    Member
    Jan 21, 2007
    13
    Hello!
    Are there any markings on the rectifier that you can post, so a cross-reference can be made?
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Anything that will handle 400 volts and 6 amps will do fine (that's overkill for safety).
  4. androsboy
    Jan 25, 2007
    Hey guys thanks for the insight, the markings on this diode is AGT60-04, maybe we can find a cross reference.
    thanks!!
  5. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    I cannot be sure but it seems to be a G6004 and is what was said by beenthere
    but is 600V 6A
    http://www.nteinc.com/specs/5800to5899/pdf/nte5850_69.pdf
    Manufacturer Part No. G6004
    NTE Part No. NTE5862
    NTE or ECG which has the same numbering scheme should be locally
    procurable. The case style of that diode is a screw in type so it may not fit. I did not find a match for ATG60-04 or ATG6004
    Is that ATG a large metal device with a threaded stud?
