Need help wiring up a simple on/off switch in a food processor
Discussion in 'The Projects Forum' started by hwally, Sep 17, 2014.
  1. hwally
    Oct 17, 2011
    I was given a Cuisinart food processor and the circuit board that controls on/off and speed is burnt out. I'd like to just wire in a simple toggle switch to turn it on and off. The motor has a start motor capacitor and a stop motor capacitor. Both capacitors run through separate resistors. I think to start the motor I would just supply power to the resistor connected to the start motor capacitor. Would I need to wire in the stop motor capacitor? If so how would it be wired? I'm a tinkerer not an engineer so simple is better. Thank you for taking the time to look at this.
  2. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,523
    What is a stop motor capacitor???
    Max.
  3. #12
    Nov 30, 2010
    16,704
    7,351
    I think it's a reversible motor. Two capacitors for 2 windings? Two capacitors as snubbers for the triacs?
    Big lack of information! Anybody have a Cuisinart schematic?
  4. faley
    Member
    Aug 30, 2014
    94
    13
    Start cap and a run cap. Yep. Where's the schematic?
  5. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,523
    I would tend to think dual speed caps, I don't see a centrifugal or other start cap switch being fitted to a small motor like that?
    Max.
  6. faley
    Member
    Aug 30, 2014
    94
    13
    Good point Max.
