Need Help wiring up 433 Mhz Reciever & Transmitter Modules:
Discussion in 'The Projects Forum' started by Lineout, Jan 1, 2014.
  1. Lineout
    Nov 20, 2013
    64
    I Bought these modules with no available schematic on how to wire them.
    One module (reciver?) says 5 v, I'm guessing the other 3 pin module would
    be a 3v transmitter (fob).
    4 pin module, (I assume the reciever), also has a marking at top xy-mk 5v.
    I know the gnd will be ground and vcc will be to the pos terminal of my
    power supply, I hooked up each data pin (one at a time) to an led , when
    powered up the led came on , but I doubt it should have with no signal
    from the transmitter, anyway I'm stuck....lol
    1) gnd
    2) Data
    3) Data
    4) VCC
    3 pin module, (I assume the Transmitter (key fob), has marking at top FS1000A.
    I also from past experience imagine the transmitter is going to need to be powered at 3 volts?
    1) ATAD
    2)VCC
    3) Grd
    Anybody know all about transmitter/recievers ?
    Thanks.....
  2. GopherT
    Nov 23, 2012
    6,297
    4,019
    Do you have photos?
    Where did you buy it? - web link is best!
    Any model numbers or manufacturer besides what may be printed on the PCB?
  3. inwo
    Nov 7, 2013
    2,435
    315
  4. inwo
    Nov 7, 2013
    2,435
    315
  5. Lineout
    Nov 20, 2013
    64
    Unfortunately , that's all I have so far.
  6. Lineout
    Nov 20, 2013
    64
    Yea, just on off is all I need.
    I have some other modules from adafruit , I think they are 415Mhz (I'll have to check) , they work great, but I need to mix up frequencies and get additional functions, hence the totally diff module exploration...
  7. inwo
    Nov 7, 2013
    2,435
    315
  8. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Shagas likes this.
  9. Brownout
    Jan 10, 2012
    2,375
    998
    You don't even know where you bought them?
  10. Lineout
    Nov 20, 2013
    64
    Sorry , no available info at this time.
  11. nerdegutta
    Dec 15, 2009
    2,565
    805
    I've used those TX & RX modules a few times, with both PIC 16F628, and PICAXE 08M2, 14M2 and 20M2.
    They are extremely easy to use with the PICAXE uC. Are you working on a schematic, circuit or source code?
  12. Lineout
    Nov 20, 2013
    64
    First one on the page is it.
    But what value capacitors do I need (it doesn't come with them) , how do you decide the value, (most any will do,or....?), why do I need them ....
    I don't have the white with red strip wires either, are the hooked to anything or one is antanae boost and other is ?
    I also see you have a little yellow thingy (wire?) attached to the upper right corner of the transmitter (for what ?)
    What type of wire do I need for the red stripped and the yellow?
    Then back to my question , other than the obvious vcc and grd what do I do with the other terminals.
    Transmitter One Data in
    Reciever Two data out
    Thanks...
  13. Lineout
    Nov 20, 2013
    64
    I think I've got the wrong item.
    I have some transmitter/reciever modules that don't have to interface with digital signals, just adding a mosfet on the receiver side to power 3 watt + loads was all I had to do to get working sets.
    Edit ( circuit I think, no logic signals )
  14. Lineout
    Nov 20, 2013
    64
    Cool, this is like some others I have with what looks like higher current solid state relays integrated.
    You can also wire these up toggle,momentary, latch within the same unit?
    What is the difference between latch and toggle, I haven't yet figured that one out, I'd think latched, like toggle stays latched until you signal it again....:shruggs:....
  15. inwo
    Nov 7, 2013
    2,435
    315
    A latch uses two buttons.
    One button to turn relay on. Latch
    Other button turns relay off. Unlatch
    Toggle uses just one button.
    Press on, press off. Like the clapper.:)
  16. Lineout
    Nov 20, 2013
    64
    Thanks....
  17. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Looks like you have standard Chinese ebay style RF modules. :)
    I added the 10uF 25v tantalum capacitors across the power pins on each module. It's just a good habit with cheap ebay modules because they are always under-capped on the power pins (to save them money as larger caps cost money).
    The "striped" wires are just antenna and ground. They connect to the antenna and gnd pins. If you have a large-ish metal box you can connect the ground to that and just have an antenna wire.
    The reason my wires have stripes is because they are old telecomms wire (single core), because single core wire is stiff enough to stand up vertically like an antenna. :)
  18. Lineout
    Nov 20, 2013
    64
    Thanks,
    They come with ebayish antenaes:p already, would your addition(wire you added) improve range ?
    By the way , how get the thing to work , I know to go vcc to 6v or so and the grnds to grounds, how do I get a line out voltage on the receiver end to 'occur' ?
    I tried feeding the 3 pin transmitter with 3 and then 6 volts while there was power to the reciever as well, but can't seem to get anything happening on the reciever end, I'd assume the data pins would both put out a voltage once the transmitter is keyed....?
  19. nerdegutta
    Dec 15, 2009
    2,565
    805
    You need to transmit something, not turning the TX and RX on. Do you have a circuit or a schematic? Perhaps some source code?
  20. Lineout
    Nov 20, 2013
    64
    Thanks,
