Need help wiring power for electric cont. Motor
Discussion in 'Power Electronics' started by Russ Cox, Jul 18, 2016.
  1. Russ Cox
    Jul 18, 2016
    I have no clue what kind of plug this is. It is attatched to an Emerson electric motor 115volt. Is there a way to re wire this to a regular 3 prong grounded plug? The wire is 14/4 red(hot), black(hot), white(neutral) , and green(ground).
  2. tcmtech
    Nov 4, 2013
    2,110
    1,750
    Yes. Cut it off and put the type of plug you want on it.
  3. Russ Cox
    Jul 18, 2016
    Thats what i would like to do but what im not sure about is... The original plug has 2 hot wires (red+black) and the regular grounded plug i need to replace it with has only black. So when i am re wiring it what do i do with the extra red wire?
  4. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,509
    What is the nature (technology) of the motor and it usage?
    Max.
  5. tcmtech
    Nov 4, 2013
    2,110
    1,750
    Knowing what the motor came from would be helpful. So would seeing how it's wired internally where the cord connects as well. One line may be of no use now for your application.
    Personally, if it was me I would just wire it up using either the red or the black line for power and see if it runs normally. If so don't worry about the rest. Either it runs corectly or it don't.
  6. Russ Cox
    Jul 18, 2016
    183513568_ge-5kc39rn383hxc1157-1-hp-electric-motor-115208-230-volt.jpg Snapchat-7738289548722525011.jpg Snapchat-2488497217728529572.jpg
    Okay here's a few more pictures okay is yours a few more pictures it is a continuous servo motor I think it could need both the red and the black wires because it is a multiple speed motor. I'm not 100% sure but I'm thinking each Hotwire is for a different speed on the engine.
  7. Russ Cox
    Jul 18, 2016
    Sorry for my google voice typing mistakes^^^^
  8. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,509
    You have a two speed 1ph induction motor there according to the plate, hence the 3rd connection.
    Max.
