Need help wiring in a reset button
Discussion in 'The Projects Forum' started by yo-yo, Jan 13, 2008.
  1. yo-yo
    Jan 13, 2008
    I need to wire in a pressure switch with a NO and NC switch in it. When the pressure goes over a certain pressure, I want it where you have to push the reset button before it will turn the compressor that it's controlling back on. It's in a 120v circuit. I think I need a relay but not exactly sure how to wire it in. Any suggestions would be appreciated.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Have a look at the attached schematic.
    You'll need a NO pushbutton switch and a 120v relay with at least DPST NO contacts, but DPDT will also work.
    Use wire nuts for your connections. Electrical tape will get gummy over time and fall off.
    [Edited to change depiction of pressure switch from NO to NC]
  3. yo-yo
    Jan 13, 2008
    Thank you SGTWookie. Looks like this will work.
