Need help wiring a single phase motor
Discussion in 'The Projects Forum' started by krofish, Nov 30, 2015.
  1. krofish
    Nov 30, 2015
    6
    Just received a single phase asynchronous motor with no wiring instructions. It is 110 volt with a start and run capacitor (already wired from motor). The rotation of the motor is not important. I am a novice to this type of wiring and simply need to know how to wire the hot, neutral and ground from a switch.
    From the top left to the posts are labeled:
    W2, U2, V2, U1, V1, W1
    Any help would be greatly appreciated!
  2. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    If you can identify the main winding which looks to me like it could be V1-V2, if so the power is connected to these two normally being the main winding there is no caps in series, the other two windings would be fed from one side of each capacitor.
    M.
  3. #12
    Nov 30, 2010
    16,703
    7,338
    I also came to the conclusion, V1, V2, but I am too timid to say so because the people who depend on us deserve better than a guess...and that's all I have, a guess.
    Of course, the green wire from the power cord goes to the metal case using any convenient screw.
    MaxHeadRoom likes this.
  4. krofish
    Nov 30, 2015
    6
    Thank you for your response. How can I identify the main winding?
  5. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    You should have three windings, two will have a capacitor connected to one of its leads.
    It may be easier to lift off all connections to check individual conductors.
    As per #12, the ground goes to the frame of the motor.
    Max.
  6. Dodgydave
    Jun 22, 2012
    5,154
    772
    I would say the Red wires are the main winding, Yellow is the start/direction winding...
  7. krofish
    Nov 30, 2015
    6
    Is there a way that I can test the resistance between terminals to determine the main winding?
  8. Externet
    Nov 29, 2005
    780
    58
  9. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    You should be able to detect three distinct an separate windings, the ones without a series cap is the main winding and the AC is connected across these.
    Max.
  10. krofish
    Nov 30, 2015
    6
    I really appreciate the reply Max but I have no idea how to detect "three distinct windings". I am an electrical idiot and have never dealt with an electric motor. Thanks
  11. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    Do you have a meter at least?
    Max.
  12. krofish
    Nov 30, 2015
    6
    Yes
  13. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    If mark or keep track of the connections and lift off each conductor you should be able to identify the three separate windings the pair with the lowest resistance is generally the run winding and this is the pair that the power would be applied to.
    The rest are taken off these via the capacitors.
    Max.
  14. krofish
    Nov 30, 2015
    6
    the resistance was as follows:
    Red to red (v1-v2) 1.5 ohms
    Yellow to yellow (w1-w2) 11.1 ohms
    Blue to blue (u1-u2) .7 ohms
    So, line and neutral to u1 and u2 and polarity is unimportant?
    Thanks again for your help!
  15. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
  16. Dodgydave
    Jun 22, 2012
    5,154
    772
    The two brass links are the mains terminals...
    Centre Live, Right Neutral
    the small blue wires are the capacitor run switch.
  17. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    Same as post #2 & #3.
    It might be advisable to take the motor into a motor shop and get them to do a quick confirmation.;)
    Max.
