Need help wiring a motor to a switch
Discussion in 'General Electronics Chat' started by XDeus, Aug 8, 2012.
  1. XDeus
    Aug 8, 2012
    5
    I'm sure this is a simple problem, but I'm a little stumped and before I start doing trial and error I thought I would look for help.
    Here is a wiring diagram of the motor I'm working with:
    I'm trying to wire it to a simple SPDT toggle switch so that I can run it CW and CCW. I know how to configure it for one or the other, but not both. Any help would be greatly appreciated!
  2. BSomer
    Member
    Dec 28, 2011
    433
    106
    I do not believe this is possible with a single pole switch. However, it is possible with a DPDT switch. You will want a switch that has a center off position so that the motor can stop before you reverse its direction. See attached drawing...
    XDeus likes this.
  3. XDeus
    Aug 8, 2012
    5
    Thanks! I wasn't entirely sure if it was possible with an SPDT switch. I'll pick up the right switch and get it connected. Thanks again.
  4. #12
    Nov 30, 2010
    16,703
    7,338
    A different way to look at the same thing...just a bit slower than BSomer.
    XDeus and BSomer like this.
  5. BSomer
    Member
    Dec 28, 2011
    433
    106
    I was about to draw it up that way too. :D
  6. XDeus
    Aug 8, 2012
    5
    That's a bit easier for me to follow. Thanks to both of you for helping me out!
  7. XDeus
    Aug 8, 2012
    5
    Okay... I'm almost there.
    I'm pretty sure I wired it according to your diagram, but it's not behaving right. When I turn it on I hear a hum from the motor, but it doesn't turn. When I switch the new DPDT switch in one direction it will move, but when I switch it to OFF or Reverse it will continue rotating in the same direction. When I unplug it and switch it in the Reverse position, it behaves the same way in that it continues to move in Reverse, but OFF and Forward have no effect and it continues to move in Reverse until I unplug it. Any suggestions? I'm sure I'm almost there, but I don't have a clue as to what is causing the anomalies.
  8. #12
    Nov 30, 2010
    16,703
    7,338
    What do you mean...DPDT switch that has forward, reverse, and off? A DPDT switch only has 2 positions: Forward and backwards. This one in particular has no way to turn the power on or off.
    As for reversing while it's running, You Can't Do That! Don't Even Try!
    There are only 3 valid states for this wiring. Post #1: the diagram on the left, the diagram on the right, and no power.
    You wire it clockwise, turn on the power, turn off the power, wait for it to come to a complete stop and then you can
    wire it counterclockwise, apply power, turn off the power, and wait for it to come to a complete stop.
    end of list.
    Too much? Sorry. I panic when good motors are in danger.
  9. XDeus
    Aug 8, 2012
    5
    Yes, it's a DPDT switch that has On-Off-On. I wasn't trying to reverse it while it was running, although I'm glad it didn't do that when I switched it. I moved it to one position, either forward or reverse, but then when I moved it to the center-Off position, it continued to run. I then moved it to the opposite position (idiot decision on my part), but it continued to run in the same direction. This is the switch that I'm using.
    Also, I'm not sure if this matters, but I have the neutral going to P1 and the hot going to T2/T4.
  10. #12
    Nov 30, 2010
    16,703
    7,338
    Your power lines are correct. They need a switch to turn one or both of them off and on. SPST or DPST would work.
    I'm glad you didn't burn up the motor. Now you know, the reverser switch has to be set in one direction or the other, then you apply power, then you switch the power off, then you don't move the reverser switch until the motor comes to a stop.
    That switch you put a link to is not a DPDT. You need a switch with 6 connectors on the bottom to make a reverser.
