Greetings!!! This is my first post on this website. Thank you in advance for any help you guys can provide with my current project. I tinker quite a lot with 12V automotive electronics, but this project is slightly beyond my level of expertise, and involves components I am not used to working with.
As stated in this thread title, I am trying to get a 130 volt DC gearmotor running. This is the motor I bought.
http://www.ebay.com/itm/271163410058?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
It is a 130VDC , 1.8A, 1/4HP, 125RPM motor.
Since I did not have a source of 130VDC power, I purchased this motor drive:
http://www.ebay.com/itm/260965161713?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
MINARIK DC DRIVE MODEL # NRGD02-D240AC-4Q
ARMATURE: 0-130 / 0-240 VDC 2 AMPS
I attempted to wire everything up this evening, and cannot get more than 5 volts DC out of the outputs for the motor drive. It appears that I have the AC input wires and DC output wires installed correctly according to the users manual for the motor drive. I placed a 10K ohm potentiometer on the motor drive per the users manual for speed control, and it has no effect on the voltage output.
Unfortunately, I do not know what questions to ask or exactly which direction to proceed from this point forward. If anyone has experience dealing with stuff like this, I can provide pictures, wiring diagrams and user's manuals for everything I am using. If I have obtained the wrong components for this project, hopefully, someone can point me in the correct direction with what will be needed to get this motor running.
Thanks again in advance for taking the time to read this, and for any help you guys can provide!!!
Will
INPUT: 115/230 VAC 4 AMPS 60 HZARMATURE: 0-130 / 0-240 VDC 2 AMPS
Will
