Need Help w/ NIMH Charging
Discussion in 'The Projects Forum' started by Shawnjohn832, Apr 20, 2012.
  1. Shawnjohn832
    Apr 20, 2012
    Im building a test box that requires a rechargeable 9V NIMH battery, could I SAFELY charge this battery with a universal 9V AC/DC adapter?? :confused:
  2. wayneh
    Sep 9, 2010
    12,382
    3,240
    No. It might be fine for the faster "bulk" charge phase, but you'd have no way to know when to taper off and terminate charging. Pop.
  3. DickCappels
    Aug 21, 2008
    2,770
    669
    You can safely trickle charge it at 1/10 the rated amp-hour capacity. However, this way, you will not charge the battery to full capacity.
  4. wayneh
    Sep 9, 2010
    12,382
    3,240
    NiMH at 0.1C? I thought that was the max continuous trickle for NiCad, not NiMH, which is less tolerant to overcharge.
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    Energizer and a Japanese Ni-MH battery manufacturer say to trickle charge at no more than C/40. They say C/10 for Ni-Cad. But a Ni-MH battery has 4 times the capacity of a Ni-Cad so the trickle current is the same.
    Some "9V" Ni-MH batteries are actually 7.2V (6-cells) or 8.4V (7-cells).
    They are fully charged at about 9V to 10.5V.
    Your 9V adapter might not have a regulated output voltage which might be 18V when the load current is low. That will destroy a 9V Ni-MH battery.
