Well I finally got around to building this circuit. It did not work. I have some more info though that could shed some light. I'm close to giving up on this, but dangit there has to be a way!
The circuit I built above does provide power to the hourmeter and the meter works....however, it works with just the ignition key ON and the engine still off....which is what I was trying to avoid. So, i've learned that the 5.4-5.6V tach signal is only when the engine is running. When the engine is off, the lead from the tach is reading 11.25V while the lead from the ignition key is reading 12.10V. So I guess because of this, since the tach lead has almost 12V with the key ON/engine off, thus not switching the transistor?
I feel we are close!
