Need help verifying a schematic diagram
Discussion in 'The Projects Forum' started by dello, Mar 4, 2009.
  1. dello
    Mar 4, 2009
    I have a schematic diagram here.. i was wondering if some of the experienced guys over here could help me verify if this circuit would work if i were to build it. Its a rather simple circuit, here is the part list for the circuit and also the diagram... hope someone could give me some comments... thanks alot
    C1 10nF ceramic disc capacitor
    C2 100nF ceramic disc capacitor
    C3 1000uF electrolytic capacitor
    D1 1N4148 signal diode
    D2 LED
    Q1 BC327 TO-92 transistor
    R1 10K 0.25W variable resistor
    R2 1K 0.25W variable resistor
    R3, R4 470R 0.5W resistor
    U1 TL072 Op-amp
    This circuit basically consists of P1 and P2 which are measurement rods driven into soil.. and a voltage will be indicated at the voltmeter attached at P3 and P4, potentiometer R1 is to adjust the range of the voltage so that it will be between the 15 v voltmeter. The op amp basically compares the value.. R2 is adjusted till the motor starts ( motor outputs are P6 and P5) the transistor amplifies the current to the motor, while the diode avoids the circuit from getting burnt from the motors inductance while the capacitors help smoother the circuits output
  2. Bernard
    Aug 7, 2008
    4,248
    423
    Should work, soil dries out, small motor comes on.
