Need help understanding this Relay
Discussion in 'The Projects Forum' started by kartthiksudhir80, Mar 28, 2015.
  1. kartthiksudhir80
    Mar 28, 2015
    6
    I could not make out where to give the wires in this locally made 1 channel 5v relay that i bought as im new to relays and this one seems to be different from the ones seen online. Any help is appreciated. Thank you. Relay pic.jpg
  2. AfdhalAtiffTan
    Nov 20, 2010
    117
    11
    I found this on Google:
    kartthiksudhir80 likes this.
  3. kartthiksudhir80
    Mar 28, 2015
    6
    Thank you so much, where should i give the ac input and where should i get the ac output from?
  4. Dodgydave
    Jun 22, 2012
    5,166
    775
    use the Com and NO terminals.
  5. DickCappels
    Aug 21, 2008
    2,780
    675
    A little more detail may be useful: Run AC Line to the relay COM (Common) contact and connect the NO (Normally Open) contact to one of the load (such as a light bulb and connect the other connection from the load to AC Neutral.
    Be sure none of the AC line connections can short or touch anything else -especially people! It is recommended that the circuit be enclosed in an insulated box.
  6. kartthiksudhir80
    Mar 28, 2015
    6
    What about the coil terminals , should i leave them open?
  7. Dodgydave
    Jun 22, 2012
    5,166
    775
    the coil connects to the 5V dc supply to operate it.
  8. kartthiksudhir80
    Mar 28, 2015
    6
    and also, what about the ground terminals?
  9. Dodgydave
    Jun 22, 2012
    5,166
    775
    connect the relay coil to a 5V dc supply and it will operate, what are you trying to make?
  10. kartthiksudhir80
    Mar 28, 2015
    6
    i just want to use a dc voltage powered switch to switch on an ac bulb, the problem is i cant make much of the locally made relay board that i have got here
  11. MaxHeadRoom
    Jul 18, 2013
    10,862
    2,525
    Post #2 can be misleading labeling all the common terminals GND especially to the initiated, one will be the 5vdc common and the other will be the switched AC.
    BUT it appears that there is two jumpers that have to be removed to switch a separate supply, it looks like they also connect the +5v supply to the contact side whith the jumpers in place?
    Check first.
    Max.
  12. Dodgydave
    Jun 22, 2012
    5,166
    775
    you need to remove the link from A to E,as shown on the pcb, to use Mains Voltage
    the 5V supply is E posative, F gnd, and connect the switch to E and G.
  13. MaxHeadRoom
    Jul 18, 2013
    10,862
    2,525
    Looks to me as they both need removing,!?
    Max.
  14. AfdhalAtiffTan
    Nov 20, 2010
    117
    11
    The OP doesn't mention that it will be used on AC power. My bad.
    Assuming you have a properly powered 5V signal, maybe it is simpler for you to use the relay directly. Just be careful, you're working with lethal voltage.
