Did you read posts #13 and #14? Those are from an engineering professor.The circuit is simple to analyze numerically.
The voltage drop over R2 is Q2's Vbe. So the current going through R2 / LED / Q1 is 0.65/33=20ma;
The base of Q1 (=Q2's collector) sits one Vbe above R2 = 0.65 + 0.65 = 1.3v;
That means the current going through R1 / Q2 = (10 - 1.3) / 10k = 1ma.
Dahdah!
You can introduce other factors in but 10% of the work (=above) gets you within 90% of the correct answers.
That's the difference between an engineer (10% input for 90% of the output) and an engineering professor (90% input for 10% of the output).
