Hi Guys,
Hope you can help me on this one, I'm working on this particular school project. I'm able to send messages to a device, however, I can't receive any.
Here's my program code, please pardon my code. I'm still learning.
Master Code:
unsigned short data[8] = "";
unsigned short address[3] = {160,161,162};
char rs_msg[5] = "";
int rxflag = 0;
int txflag = 0;
int x = 0, i = 0;
int iIndex = 0;
int pc_msg = 0;
void enable_interrupt()
PIE1.RCIE = 1; // Enable interrupt
INTCON.PEIE = 1; // on byte received
PIE1.TXIE = 0; // via USART (RS485)
INTCON.GIE = 1; // Set into receive status
void disable_interrupt()
PIE1.RCIE = 0; // disable interrupt
INTCON.PEIE = 0; // on byte received
INTCON.GIE = 0;
void send_pc()
int y = strlen(rs_msg);
int ind = 0;
while (y > 0){
if(rs_msg[ind] != '<' && rs_msg[ind] != '>' )
Usart_Write(rs_msg[ind]);
Lcd_Custom_Chr(3,1,rs_msg[ind]);
delay_ms(300);
y--;
ind++;
void clear_rs_data()
int ind = strlen(rs_msg);
lcd_Custom_chr_cp(ind+48);
while(ind >= 0){
rs_msg[ind] =0;
ind--;
x = 0;
void clear_bufferData()
int ind = strlen(data);
while(ind >= 0){
data[ind] =0;
ind--;
x=0;
void interrupt(void)
RS485Master_Receive(data);
if(data[0])
rxflag = 1;
void showRoomNo()
unsigned short j = 0;
data[4] = 0; //Clear message received flag
delay_ms(100);
j = data[3]; //Number of data bytes received
for (i = 0; i < j; i++) {
rs_msg = data[x];
x++;
Lcd_Custom_Cmd(LCD_CLEAR);
Lcd_Custom_Out(2,2,"Room Number: ");
Lcd_Custom_Out(2,16,rs_msg);
delay_ms(100);
void main () {
char sReminder[21] = "";
TRISC.F2 = 0;
TRISD.F1 = 0;
Lcd_Custom_Config(&portb,1,2,3,4, &portb, 7,6,5);
Usart_Init(9600); // Initialize usart module
RS485Master_Init(&PORTC, 2);
Lcd_Custom_Out(1, 1,"Master");
delay_ms(1000);
Lcd_Custom_Cmd(Lcd_Clear);
while ( 1)
enable_interrupt();
if (rxflag == 1)
while (rs_msg[x-1] != '>')
if (rxflag == 1) {
showRoomNo();
disable_interrupt();
send_pc();
Lcd_Custom_Out(4,1,"sent to pc");
rxflag = 0;
clear_rs_data();
clear_bufferData();
else
Usart_write(pc_msg);
Slave Code:
//--------------------Declaration of Global variables------------------->
char msg[3]="1";
char roomNo[5]="<1>";
int temp[21];
int i=0;
int k=0;
int rxflag=0;
int j=0;
int index=0;
unsigned short data[8] = ""; // buffer for receiving/sending messages
//------------------End of declarations------------------>
//------------------Function declarations---------------->
void interrupt();
void clear_temp();
void ipakita();
void clear_bufferData();
void clear_roomNo();
void send_roomNo();
void display_rs();
void erase_rs_data();
//--------------End of function declaration-------------->
//------------------Function operations------------------>
void interrupt (void)
RS485Slave_Receive(data);
if (data[3] > 0)
rxflag = 1;
void enable_interrupt ()
PIE1.RCIE = 1;
INTCON.PEIE = 1;
PIE1.TXIE = 0;
INTCON.GIE = 1;
void disable_interrupt ()
PIE1.RCIE = 0; // Enable interrupt
INTCON.GIE = 0;
void send_roomNo ()
int temp1=0;
int temp2=0;
int temp3 =0;
int ind =0;
int res1 =0;
int res2 =0;
char room[4]="";
temp3 = strlen(roomNo);
res1 = temp3/3;
res2 = temp3%3;
while (temp2 < res1) {
for (temp1 =0;temp1<3;temp1++) {
room[temp1] = roomNo[ind];
ind++;
RS485Slave_Send(room, 3);
delay_ms(500);
temp2++;
if (res2 > 0 && res2 < 3) {
for (temp1 =0;temp1<res2;temp1++) {
ind++;
RS485Slave_Send(room, res2);
delay_ms(500);
void showRoomNo()
delay_ms(108);
j = data[3]; // Number of data bytes received
for (k = 0; k < j; k++) {
msg[k]=data[k];
data[k] = 0;
Lcd_Custom_Out(4, 10,msg);
void erase_rs_data ()
int ind= 0;
ind= strlen(msg);
while(ind >= 0){
msg[ind] =0;
ind--;
void clear_temp ()
int val=0;
for (val=0;val<i;val++){
temp[val]=0;
i=0;
void clear_bufferData ()
int val=0;
for (val=0;val<9;val++){
data[val]=0;
void clear_roomNo ()
int val=0;
for (val=0;val<=i;val++){
roomNo[val]=0;
//---------------End of function operations-------------->
void main () {
char sReminder01[21] = " Time to Take";
char sReminder02[21] = " Medicine";
TRISB = 0x00; //set portB as input
TRISC.F2 = 0; //set portC pin2 as output
TRISD.f0 = 1;
TRISD.f1 = 1;
Lcd_Custom_Config(&portb, 1,2,3,4, &portb, 7,6,5); //initialize lcd
Usart_Init(9600);
RS485Slave_Init(&PORTC, 2, 160); // Initialize MCU as Slave with address 160
Lcd_Custom_Out(1,1, "Slave 1");
delay_ms(1000); // Initialize baud rate
while (1)
enable_interrupt();
if(portd.f0 == 0 || portd.f1 == 0)
Lcd_Custom_Out(1,1, "Sending Message...");
send_roomNo();
if (rxflag == 1)
Lcd_Custom_Out(2,5,sReminder01);
Lcd_Custom_Out(3,7,sReminder02);
rxflag=0;
clear_bufferData();
erase_rs_data();
Master Code:
int rxflag = 0;
int txflag = 0;
int x = 0, i = 0;
int iIndex = 0;
int pc_msg = 0;
INTCON.GIE = 0;
void send_pc()
int ind = 0;
while (y > 0){
delay_ms(300);
y--;
ind++;
while(ind >= 0){
rs_msg[ind] =0;
ind--;
x = 0;
while(ind >= 0){
data[ind] =0;
ind--;
x=0;
if(data[0])
rxflag = 1;
void showRoomNo()
delay_ms(100);
rs_msg = data[x];
x++;
delay_ms(100);
void main () {
TRISC.F2 = 0;
TRISD.F1 = 0;
delay_ms(1000);
while ( 1)
enable_interrupt();
if (rxflag == 1)
if (rxflag == 1) {
showRoomNo();
send_pc();
rxflag = 0;
clear_rs_data();
clear_bufferData();
else
Slave Code:
char msg[3]="1";
int temp[21];
int i=0;
int k=0;
int rxflag=0;
int j=0;
int index=0;
void interrupt();
void clear_temp();
void ipakita();
void send_roomNo();
void display_rs();
if (data[3] > 0)
rxflag = 1;
PIE1.RCIE = 1;
INTCON.PEIE = 1;
PIE1.TXIE = 0;
INTCON.GIE = 1;
INTCON.GIE = 0;
void send_roomNo ()
int temp1=0;
int temp2=0;
int temp3 =0;
int ind =0;
int res1 =0;
int res2 =0;
char room[4]="";
res1 = temp3/3;
res2 = temp3%3;
ind++;
delay_ms(500);
temp2++;
ind++;
delay_ms(500);
void showRoomNo()
delay_ms(108);
msg[k]=data[k];
data[k] = 0;
int ind= 0;
ind= strlen(msg);
while(ind >= 0){
msg[ind] =0;
ind--;
void clear_temp ()
int val=0;
temp[val]=0;
i=0;
int val=0;
data[val]=0;
int val=0;
roomNo[val]=0;
void main () {
TRISD.f0 = 1;
TRISD.f1 = 1;
Usart_Init(9600);
while (1)
enable_interrupt();
send_roomNo();
if (rxflag == 1)
rxflag=0;
clear_bufferData();
erase_rs_data();
