Need help troubleshooting sound-activated switch
Discussion in 'The Projects Forum' started by disjectia, Jan 19, 2016.
  1. disjectia
    Jan 18, 2016
    Hey all - I just posted this in General Electronics, meant to post here in Circuits.
    I've been working on adapting a schematic I found here on youtube (versions of which seem widely available elsewhere).
    I've successfully breadboarded a build of the above switch (version A in the drawing below). The only differences in my build (A) versus the above are the value of R1 and the fact my supply voltage is +9V instead of +5V. Even so, my build of the circuit works great. When I clap, I get DC voltage on the output of the 555.
    The main alteration I require is to replace the electret condenser mic with an 1/8" input jack (which will be connected to the headphone jack of an iPhone). The schematic for the revised circuit is version B.
    For some reason, however, as soon as I remove the condenser mic I get a constant voltage on the output of the 555 - there's no fluctuation and the signal from the input jack has no effect. I've experimented with the value of C1 in this version (the advice I was given was to work in the range of .01uF to .1uF) and every other variation I can think of to no avail. The circuit only works when the condenser mic is in it.
    Does anyone have any idea how I might revise this design for use with a 1/8" jack? Or even a different design entirely? I just need the thing to work.
    Ultimately I'm planning to run the circuit off +12V. I'll be using the output of the 555 to trigger a relay which will cause a solenoid to fire. I need the solenoid firing in time with a click track, hence the desire for an 1/8" jack. The solenoid is actuating the movement of a toy, making it appear to dance in time with a song.
    I'd be most grateful for any advice. I'm happy to provide any more info that might be useful.
    Thanks in advance!
  2. Nykolas
    Member
    Aug 27, 2013
    92
    31
    First off: Do not double post!
    Second: Neither circuit is going to work reliably. There is to much wrong with either circuit to start explaining (for me at least). Read up on transistor biasing and use one of the other circuits you mentioned. E
  3. hp1729
    Nov 23, 2015
    2,105
    235
    I would suggest omitting the transistor on the right.
