all the info on the design can be found here: http://desmith.net/NMdS/Electronics/NixiePSU.html
i didn't change anything from the original design except for a few minor components that where no longer available from digikey. the problem I'm having though, is there is no hv output... I've spent a few hours going over the board with my multi-meter checking that all the components are properly soldered to the board. i used the eagle files provided to order a PCB from OSH Park. any ideas as to how to troubleshoot this would be greatly appreciated!
c4 was replaced with http://www.digikey.com/product-search/en?KeyWords=PCE3432CT-ND&WT.z_header=search_go
c5 was replaced with http://www.digikey.com/product-search/en?KeyWords=399-3851-1-ND&WT.z_header=search_go
l1 was replaced with http://www.digikey.com/product-search/en?KeyWords=513-1093-1-ND&WT.z_header=search_go
