Need Help Transformer design
Discussion in 'General Electronics Chat' started by bencyp, Jun 17, 2010.
  1. bencyp
    Jun 16, 2010
    I would like to build a transformer for an Invertor of 1000W.
    Primary Input 24V
    Sec output 240V
    Frequncy 50Hz
    Watts 1000W
    Can anyone tell me the Primary & Secondary winding details along with the size of the bobin and size of the coper wire?
    Regards,
    Bency
  2. R!f@@
    Apr 2, 2009
    8,792
    771
    Can you get the necessary "E" "I" laminates for the transformer core
  3. dsp_redux
    Apr 11, 2009
    182
    5
    In your case:
    \frac{V_s}{V_p} = \frac{240V}{24V} = 10 = \frac{N_s}{N_p} = \frac{I_p}{I_s}
    You should be able to get all the other informations with very little research.
