need help to start a speed display circuit
Discussion in 'The Projects Forum' started by neiji, Mar 2, 2008.
  1. neiji
    Jul 25, 2007
    19
    I would like to make a speed display circuit. it would measure amount of pulses say in 10 seconds and it would display it on a seven segment display. i would like to implement it using a pic. how should i proceed?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You will need to learn how to program the PIC. You will need enough electronic knowledge to present the PIC with pulses it can take in. You will need to understand what it takes to drive a 7 segment display.
    It's a good starting project for getting familiar with a PIC. There are easier ways to make a tachometer or speedometer.
  3. h.d
    Oct 22, 2007
    150
    or use shaft encoder as input to the PIC. then process the pulsses to take the speed.
