Hello friends,
I am a starter in PIC and I have done a program in pic c complier for the following problem
_____________________________________________________________
When PIC A0 receives an input of more than 4 v, it is converted into digital output and that is fed to a counter. When the count reaches 5 the memory is incremented by 1 and is multiplied with 3 and displayed as cost as well as the counter is reset.
These are displayed in a LCD 16*2 screen. whenever the cost goes above 20, a message is sent via sms using a gsm 900 module to a pre described number. and finally the cost is reset to 0.
I have attached a word file of the program. The problems i face is the LCD display is not working as well as the message is not sent over the gsm.
_________________________________________________________________
Now the problem is program works fine with proteus model but in real time it dosen't work. Even the LCD 1682 display is not diplaying the result as well as there is no message being sent over the gsm.
Can anyone help me with this program and tell me what are the errors i have done..
Thanks in advance.. Hoping to receive some help.
This the program which i did for PIC 16f877a:
Rich (BB code):
#include"C:\Users\vijay\Desktop\project\Program for\main.h"
#bit lcdrs=0X09.2
#bit lcde=0X09.0
#bit lcdrw=0X09.1
#byte lcddata = 0x8
void lcdinit();
void lcdclear();
void lcdclock();
void lcddly();
void line1();
void line2();
void lcdputc(char c);
//unsigned char disp[16],discou,dl;
void lcddly()
delay_ms(1);
void lcdxy(char r,char c)
if(r==1)
lcdrs=0;
lcddata=0x80+c;
lcdclock();
lcdrs=1;
else if(r==2)
lcdrs=0;
lcddata=0xC0+c;
lcdclock();
lcdrs=1;
void lcdinit()
lcde=0;
lcddata=0x38;
lcdrs=0;
lcdclock();
lcddata=0x14;
lcdclock();
lcddata=0x0c;
lcdclock();
lcddata=0x06;
lcdclock();
lcddata=0x01;
lcdclock();
lcdrs=0;
lcddata=0x80;
lcdclock();
void lcdclock()
lcde=1;
lcddly();
lcde=0;
lcddly();
void lcdclear()
lcdrs=0;
lcddata=0x01;
lcdclock();
lcddata=0x0c;
lcdrs=0;
lcdclock();
switch(c)
case '\f':
lcdrs=0;
lcddata=0x01;
lcdclock();
lcddata=0x0c;
lcdrs=0;
lcdclock();
lcdrs=0;
lcddata=0x80;
lcdclock();
lcdrs=1;
}break;
case '\n':
lcdrs=0;
lcddata=0xc0;
lcdclock();
lcdrs=1;
}break;
default:
lcddata=c;
lcdclock();
int value;
int8 c=0,cost=0,d,u=0,a;
void main()
start:
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_INTERNAL);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_16,127,1);
setup_comparator(NC_NC_NC_NC);
setup_vref(FALSE);
set_adc_channel(0);
delay_us(20);
set_tris_b(0xFF);
set_tris_d(0X00);
set_tris_e(0X00);
set_tris_a(0xF0);
set_tris_c(0x0F);
lcdinit();
lcdclear();
lcdxy(1,0);
lcdclear();
// for(qw=0;qw<=2;qw++)
while(1)
delay_ms(1);
value=read_adc();
lcdinit();
lcdclear();
lcdxy(1,0);
lcdclear();
lcdxy(1,0);
printf(lcdputc, "count:%d",d);
if(value>=31)
c++;
d=c;
lcdinit();
lcdclear();
lcdxy(1,0);
lcdclear();
lcdxy(1,0);
//delay_ms(100);
if(d>=5)
u++;
a=u;
c=0;
cost=(u*3);
lcdinit();
lcdclear();
lcdxy(1,0);
lcdclear();
lcdxy(1,0);
//delay_ms(100);
printf(lcdputc,"Units:%d",a);
printf(lcdputc, " Cost:%d", cost);
goto start;
if (cost>=20)
//serial_init(9600);
printf("AT\n");
delay_ms(20); // 2 sec delay
printf("AT+CMGF=1\n");
printf("AT+CMGS=\"09825858509\"\n");
printf ("Cost=%d ", cost); // sends ADC value as SMS
putchar(26); // Ctrl-Z indicates end of SMS and transmit
cost=0;
else
{ goto start;
