need help to solve the ir distance sensor
Discussion in 'Embedded Systems and Microcontrollers' started by hasnannordin, Oct 9, 2009.
  1. hasnannordin
    Oct 9, 2009
    HI.I'M WORKING FOR MY FINAL YEAR PROJECT WHICH IS I MAKE TO MAZE MAPPER ROBOT.FOR THIS PROJECT I USE 3 IR SENSORS (sharp GP2D120XJ00F),2 12VDC MOTOR WITH ENCODER (PD3046) AND 1 PIC18F4550 MICROCONTROLLER.I HAVE MAKE THE SENSORS CODING SEPARATELY BUT I CAN'T COMBINE THE 3 SENSORS CODING INTO 1 CODING.I'VE TRIED TO COMBINE THE SENSORS CODE BUT IT'S DOESN'T WORK AT ALL.HOW CAN I COMBINE THE 3 SENSORS?THERE'S ANYBODY CAN HELP ME TO SOLVE THE PROBLEM.FOR YOUR INFORMATION, I CONNECT THE 3 SENSORS AT THE PORTA0-A2.I ATTACH MY SENSORS CODE BELOW:
    COMBINATION OF 3 SENSOR
    define osc 8
    defenition
    DEFINE CCP1_REG PORTC ' Hpwm 1 pin port
    DEFINE CCP1_BIT 2 ' Hpwm 1 pin bit
    DEFINE CCP2_REG PORTC ' Hpwm 2 pin port
    DEFINE CCP2_BIT 1 ' Hpwm 2 pin bit
    DEFINE ADC_BITS 8 ' Set number of bits in result (8, 10 or 12)
    DEFINE ADC_CLOCK 3 ' Set clock source (rc = 3)
    DEFINE ADC_SAMPLEUS 50 ' Set sampling time in microseconds
    MRCW1 VAR PORTD.4
    MRCCW1 VAR PORTD.5 'MOTOR RIGHT DRIVE
    MRCW2 VAR PORTD.6
    MRCCW2 VAR PORTD.7 'MOTOR LEFT DRIVE
    TRISD.4=0
    TRISD.5=0
    TRISD.6=0
    TRISD.7=0
    TRISA=1
    ADCON1=%00001110
    SENSOR1 VAR BYTE
    SENSOR2 VAR BYTE
    SENSOR3 VAR BYTE
    HPWM 1,150,1000
    main program
    MAIN:
    GOSUB fwd
    pause 1000
    GOSUB IR1
    PAUSE 1000
    GOSUB IR3
    PAUSE 1000
    GOSUB IR2
    PAUSE 1000
    GOTO MAIN
    FWD:
    HPWM 1,150,500
    MRCCW1=0
    MRCW1=1
    HPWM 2,150,500
    MRCCW2=1
    MRCW2=0
    RETURN
    IR1:
    ADCIN 0,SENSOR1
    IF SENSOR1>46 THEN
    GOSUB RIGHT
    pause 1000
    ELSE
    if SENSOR1<46 THEN
    GOSUB FWD
    pause 1000
    ENDIF
    ENDIF
    pause 1000
    RETURN
    IR2:
    ADCIN 1,SENSOR2
    IF SENSOR2>46 THEN
    GOSUB BWD
    pause 1000
    ELSE
    if SENSOR2<46 THEN
    GOSUB fwd
    pause 1000
    ENDIF
    ENDIF
    pause 1000
    RETURN
    IR3:
    ADCIN 2,SENSOR3
    IF SENSOR3>46 THEN
    GOSUB LEFT
    pause 1000
    ELSE
    if SENSOR3<46 THEN
    GOSUB FWD
    pause 1000
    ENDIF
    ENDIF
    pause 1000
    RETURN
    RIGHT:
    HPWM 1,150,500
    MRCCW1=0
    MRCW1=1
    HPWM 2,150,500
    MRCCW2=0
    MRCW2=0
    RETURN
    LEFT:
    HPWM 1,150,500
    MRCCW1=0
    MRCW1=0
    HPWM 2,150,500
    MRCCW2=1
    MRCW2=0
    pause 1000
    RETURN
    BWD:
    HPWM 1,150,500
    MRCCW1=0
    MRCW1=1
    HPWM 2,150,500
    MRCCW2=1
    MRCW2=0
    PAUSE 1000
    GOSUB RIGHT
    RETURN
    FOR THE SEPARATE CODE OF SENSOR:
    SENSOR 1
    define osc 8
    'defenition
    MRCW1 VAR PORTD.4
    MRCW2 VAR PORTD.6
    TRISD.4=0
    TRISD.5=0
    TRISD.6=0
    TRISD.7=0
    TRISA.0=1
    ADCON1=%00001110
    SENSOR1 VAR BYTE
    HPWM 1,150,1000
    'main program
    MAIN:
    GOSUB fwd
    pause 1000
    GOSUB IR1
    GOTO MAIN
    FWD:
    HPWM 1,150,500
    MRCCW1=0
    MRCW1=1
    RETURN
    IR1:
    ADCIN 0,SENSOR1
    IF SENSOR1>46 THEN
    GOSUB BREAK
    ELSE
    if SENSOR1<46 THEN
    GOTO MAIN
    ENDIF
    ENDIF
    pause 1000
    GOTO IR1
    BREAK:
    HPWM 1,150,500
    MRCCW1=0
    MRCW1=0
    RETURN
    AND FOR SENSOR 2
    define osc 8
    'defenition
    MRCW1 VAR PORTD.4
    MRCW2 VAR PORTD.6
    TRISD.4=0
    TRISD.5=0
    TRISD.6=0
    TRISD.7=0
    TRISA.1=1
    ADCON1=%00001100
    SENSOR2 VAR BYTE
    HPWM 1,150,1000
    MAIN1:
    GOSUB FWD
    pause 1000
    GOSUB IR2
    GOTO MAIN1
    FWD:
    HPWM 1,150,500
    MRCCW1=0
    MRCW1=1
    pause 1000
    RETURN
    IR1:
    ADCIN 1,SENSOR2
    IF SENSOR2>46 THEN
    GOSUB BREAK
    ELSE
    if SENSOR2<46 THEN
    GOTO MAIN1
    ENDIF
    ENDIF
    goto IR2
    BREAK:
    HPWM 1,150,500
    MRCCW1=0
    MRCW1=0
    RETURN
    PLEASE HELP ME,I'M DESPERATELY NEED THE SOLUTION OF MY PROBLEM.THANK YOU.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Just convert the sensor inputs in sequence. Assign the results to separate variables and evaluate your navigation using those numbers.
    Or do you have some other meaning in the phrase -
