Hi
Several years ago I set up a "panic" alarm system for some county offices which would signal the sheriff's department that law enforcement officers were needed at the location initiating the alarm. I now need to expand this from 3 zones up to 6 zones or offices. I would like to try and improve on the current display
method and then add possibly 3 more. What I have is three display "boxes" which have a red cover and
sirens inside. Each is labeled so that the dispatcher can see where the alarm came from. There isn't a whole
lot of room for these items so I'd like to use some smaller red (possibly LED) lights with siren and label them.
With 6 they will get pretty bulky and space consuming.
I'm thinking of some type of panel with the lights mounted in a hole and protruding through and a separate (if not self contained) siren or piezo sounder. The sounder could be just a single unit but wired so it will go off no matter which area created the "panic" call.It would be best for each to have a "test" button to simulate
an alarm trigger to show the display and sounder are working and a "reset" button. Right now, when an
alarm is sent, the light and sounder remain on until someone resets or cancels it at the dispatcher's desk.
(this is so if someone has stepped out of the room a minute or two that they will see the alarm as soon as
they return. ) The link below shows what I am currently using.... have three of these in a row and covers
labeled.
http://www.goodluckbuy.com/w-102-mini-12v-security-wired-outdoor-alarm-strobe-light-siren-red.html
Also would like some suggestions or help regarding the circuitry where I have a latching relay which keeps
the alarm display/sounder going until reset... will follow up with those details when someone feels they
would be able to help out.
Thanks very much!
labeled.
Thanks very much!
