Need help to repair multimeter
Discussion in 'Technical Repair' started by vead, Sep 10, 2016.
  1. vead
    Nov 24, 2011
    621
    8
    Hello
    I need help to repair my digital multimeter. There is display error It does not show value
  2. AlbertHall
    Jun 4, 2014
    2,256
    446
    Most likely the connections between the display and the circuit board are faulty. Generally these are unrepairable without special equipment.
    vead likes this.
  3. vead
    Nov 24, 2011
    621
    8
    Hello AlbertHall
    That means I have to buy new multimeter
    Which type of special equipment are you talking?
  4. AlbertHall
    Jun 4, 2014
    2,256
    446
    There are generally two methods used to make the connections to the glass of the LCD.
    1. A rubber strip divided into very small conducting and insulating sections squashed between the LCD and the board.
    2. A clear (usually) flexible PCB strip which is attached by conductive glue to the LCD and the board.
    I don't know details of how these are produced/attached but I have tried to repair such with no success (40 years servicing electronic things).
  5. wayneh
    Sep 9, 2010
    12,368
    3,224
    In the U.S. there is a store that gives away meters like that for free, called Harbor Freight.
    That doesn't help you, but my point is that such a meter is very inexpensive. The battery inside is worth more than the meter. I would not invest time in fixing it, but instead spend time finding another one.
    vead likes this.
  6. RichardO
    May 4, 2013
    1,334
    429
    Even though it can't be repaired it still has value!
    Open it up and look at how it is built. You can learn a lot that way.
  7. SLK001
    Nov 29, 2011
    849
    242
    It looks like the connections between the LCD and the PCB are just fine. You probably have a bad main chip. This is not economically repairable.
    Buy a new meter.
