Need Help to identify fuse
Discussion in 'General Electronics Chat' started by pmoodie, Feb 5, 2007.
  1. pmoodie
    Jan 31, 2007
    5
    I do not have a photo uploade yet, but I desoldered a burnt fuse from my Zenith Projection TV. It was coated in white, I am assuming a cermaic type material, had the number 6 on one end and rotating it about 45 degrees shows a number 2. The coating came off and the fuse looks like it is spiraled in the center. Any Ideas??? I am a complete beginner.:confused:
  2. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    Look for a paper label somewhere on the inside of the TV. There should be a small one near the fuse with that information. There should also be a larger label with that information inside.
    The voltage and rating should have been stamped in the metal of the fuse.
    If it's soldered in it's probably not a fuse but a fusable resistor. Is it rectangular cube?
  3. pmoodie
    Jan 31, 2007
    5
    There is a couple of labels around the board, but the only thing close to this component is the mark R3267. It is cylinder shaped, not rectangular.
  4. pmoodie
    Jan 31, 2007
    5
    I just contacted Zenith and found part R3267 and it has been discontinued. It was substituted, but then THAT part was also discontinued!! So is my Big Screen trash just because of this tiny little component!?!? Couldn't make out what he called it... sounded like he said either amp resistor or m resistor... somethign along those lines... anyone know a way around this discontinued part? Help!!!
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    What's the model number on the projector?
  6. pmoodie
    Jan 31, 2007
    5
    Model Number is PV6069RK manufactured in 1995
  7. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Try 4.7 ohm 1 watt, if you can find one. I have no clue where to begin looking for such an animal.
  8. wireaddict
    Nov 1, 2006
    133
    Could it have been a thermistor? I you want to use a 4.7 ohm, 1 W resistor here, I'd use a wirewound type, I think Mouser probably sells power resistors. If not, Google International Resistor Corporation [IRC].
