Need help to identify a component
Discussion in 'General Electronics Chat' started by Molteneng, May 10, 2011.
  1. Molteneng
    May 10, 2011
    Help identify ceramic disc capacitor Hello,
    I have a burned component and urgently need to replace the part to get a power supply module working. Will appreciate anyone who can help me.
    CM
    .1M
    1KV
    E
    It is orange, with 2 leads and is about 10mm diameter round and flat. Can anyone help me identify the trade number or spec so I can order replacement?
    You can email to me at <snip>
    Thanks,
  2. tom66
    May 9, 2009
    2,613
    214
    Looks like a ceramic disc capacitor. Not sure about value though.
    These rarely fail; other things may have caused the failure of this. Replacing this cap is unlikely to fix the underlying cause of its failure.
  3. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    It is a .1uF, 1Kv ceramic disc capacitor. I have seen these fail several times before, though it will be a good idea to check other components on the board, as well.
    Der Strom
  4. radiohead
    May 28, 2009
    474
    31
    CM is the case code for a molded case style. .1M means the ceramic disc capacitor has a value of .1 microfarad. M is the tolerance +/- 20%. The capacitor is rated at 1,000 volts. I believe E is the temperature coefficient of -20 to +100ppm/ Degrees Celcius.
  5. Molteneng
    May 10, 2011
    Could it be a surge arrestors or big thermistors
  6. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  7. radiohead
    May 28, 2009
    474
    31
    It's not a thermistor. It's a capacitor.
  8. Molteneng
    May 10, 2011
    Thanks radio head, Do you happen to know where can i order that capacitor?
  9. Triden
    May 10, 2011
    8
  10. Omar Karshe
    May 4, 2015
  11. Omar Karshe
    May 4, 2015
    Sorry for the very late reply, but found myself looking for the same component this week. This is Ceramic Capacitor, 0.1 UF, 1000v DC with 20% tolerence. If it is already burnt, it must be replaced ofcourse, but you still need to figure out the cause or the faulty component that caused it. Because, it likely to hapen again. Here is the manufacturer Part #: 565R10GAP10, and here is the link in case you eant to order it http://avnetexpress.avnet.com/store...3DKNC-Express_Dynamic&CMP=KNC-Express_Dynamic
