Need help to design a counter that follows a given sequence using D Flip Flops
dragstang86
Joined Nov 11, 2010
5
I need to design a counter diagram that follows a count sequence 0-2-4-1-0 using DFFs.
The characteristic equation for the DFF is Q+ = D. I have the sequence in the present state and next state table but don't know where to go from there.
Rich (BB code):
Present State | Next State|Da |Db |Dc |
000           | 010       | 0 | 1 | 0
010           | 100       | 1 | 1 | 0
100           | 001       | 1 | 0 | 1
001           | 011       | 0 | 1 | 0
011           | 000       | 0 | 1 | 1
I appreciate any help. I have been trying to find a similar example for hours with no luck.
I think what the main thing I need help with is how to go from the state table to the k-map. If what I have done in the state table is correct. So I guess the first question is, is my state table correct?
Thanks for your help
dragstang86
Joined Nov 11, 2010
5
Be sure of your assignment. Your table shows a sequence 0-2-4-1-3-0.
Thanks! The 3 shouldn't be in there. I mixed the numbers up with a state graph that I just put together that used that sequence. I couldn't figure out how to edit my post but it should read:
001 | 000 | 0 | 0 | 1
bertus
Joined Apr 5, 2008
22,277
In the eBook at the top, there is this page on D flip-flops:
http://www.allaboutcircuits.com/vol_4/chpt_10/4.html
An other page with a lot of links is this one on the EDUCYPEDIA:
http://www.educypedia.be/electronics/digitalflipflops.htm
There are more pages like that over there on other digital subjects:
Digital electronics:
Arithmetic circuits D/A-A/D converters Number systems Codes and decoders Flip flops Technology Counters and registers General overview Technology-CMOS Digital logic Memories Technology-TTL Timers and oscillators
Bertus
Georacer
Joined Nov 25, 2009
5,182
4-bit actually; zero counts as information. It's a clever idea but usually homework assignments are very specific on the implementation methods.
