Need help to debug Electronic Speed Controller(ESC)
Discussion in 'General Electronics Chat' started by pragneshvirani, Mar 18, 2016.
  1. pragneshvirani
    Mar 9, 2013
    I have XM30A ESC supplies by 1300mAh 4S battery and MT1806-2280KV brushless motor.I am trying to run motor with this setup. once I supply power get beep sound. after that no motion.I tried to give 5v pulse from signal generator but no motion.
    Any Idea or suggestion on this problem.
    I have some points on setup:
    1) Do I need to have some specific connection between ESC & motor because motor has no color coding(all 3 wires are black)
    2) There Is only two wires on ESC control,yellow and black.to yellow signal I am supplying PWM signal.because I see short between black wire with ESC input supply GND.so assumed as GND.Any difference with 3 wire control?
    3)Can I supply 5v/3.3v continuously to control signal,so 100% duty cycle?
    4)Does control voltage level varies with different ESC?
    Once I confirm with hardware setup then I am planning to control it with Raspberry PI 2.
    Thanks in advance.
    Regards,
    Pragnesh
  2. MaxHeadRoom
    Jul 18, 2013
    10,850
    2,521
  3. Alec_t
    Sep 17, 2013
    5,972
    1,135
    What does the datasheet/manual for the ESC tell you about the control input requirements?
