need help to control a room temperature of 57deg C??
lagmaster
Joined Oct 11, 2008
if you have a circuit available that would be a big help..
i need to control a room temperature from 56-58 deg C...
circuit is a big help.. thank you
beenthere
Joined Apr 20, 2004
15,819
There are more than one way do do this. When you have selected a method, come back with specific questions.
It is not clear if you are designing a thermostat or a heater/furnace.
Wendy
Joined Mar 24, 2008
23,429
58° C? 136° F?
Kinda hot, isn't it?
There are a lot of commercial solutions (Omega Electronics comes to mind).
thingmaker3
Joined May 16, 2005
5,083
In a sealed room with good air circulation, an ordinary thermostat would work. Otherwise, a PID system might be in order.
What is the nature of the system? How much thermal hysteresis do you expect?
Wendy
Joined Mar 24, 2008
23,429
I'm curious if the OP meant the temperature he said. I checked, my digital thermostat only goes to 99°F.
thingmaker3
Joined May 16, 2005
5,083
Perhaps "ordinary" was a bad choice of words on my part. "Simple" may have been a more accurate adjective.
If the thermal hysteresis of the system is low enough, a simple thermostat will suffice.;) Larger thermal hysteresis will require PID.
