Need help to construct a mod 16 counter
Discussion in 'General Electronics Chat' started by vivek1925, May 12, 2010.
  1. vivek1925
    May 12, 2010
    11
    Hi guys,
    I have a difficulty to understand how to connect the inputs and the clock pulse for a 4 bit synchronous 74LS163A counter. I am sure to connect my output pins to LED's for displaying out my count but with the inputs pins on 3,4,5,6 i have a serious problem.
    Anyone who can give me a brief idea, so that i can make a head start.
    Thank you
  2. retched
    Dec 5, 2009
    5,201
    313
  3. vivek1925
    May 12, 2010
    11
    thank you i will go through them straight away
  4. vivek1925
    May 12, 2010
    11
    Thanks for the link , but the link for the awatronix is broken. Is there any alternative .?
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    A mod 16 counter is a simple 4 flip flop counter (binary 4 bits), the chip your using is major overkill. Try grounding the input pins, do not use the load pin, and try it out.
