need Help to configure the USB in MLA
Discussion in 'Embedded Systems and Microcontrollers' started by ep.hobbyiest, Oct 4, 2014.
  1. ep.hobbyiest
    Aug 26, 2014
    96
    i am using mla in that HID_custom code i am using. controller is 18f4550 and xc8 compiler.
    i started to configure the code for my application but after commenting ADCON0 register usb doen't work. Why?
    i saw analog pins are not multiplex with USB data pins.
    Then also what is wrong with the code?
    And also if i delete the code of keys and ADC then also code not working neatly.
