Need help to calculate a couple of resistors
tavo91
Joined Jul 11, 2016
15
Hi, I need some help to calculate the value of some resistors for a problem that I am trying to make.
I have a signal of 0 to 5 V(That part is not important I am not taking that in consideration in my circuit drawing) and I need to connect a fan of 120 VAC and 1200 walts(So I need a 10 A in the circuit ) so I already have the circuit but I am missing the values of the resistors so if somebody can help me explain how to calculate this values it will be really appreciate.
PD: If you guys think that my components can be better please let me know(MOC 3010 and BT137 )
Papabravo
Joined Feb 24, 2006
21,226
To start with you need an estimate, from the datasheet for the MOC3010, of the forward voltage drop of the diode on the input side of the MOC3010. You also need to estimate the current you want to flow in the input diode of the MOC3010, in order for it to turn on the output TRIAC. That will allow the determination of R1.
DickCappels
Joined Aug 21, 2008
10,186
It can become complicated and I don't have a good model to share, but the answer is presented in figures 9 and 10 of the pdf file at the URL below.
http://www.ti.com/general/docs/lit/getliterature.tsp?genericPartNumber=moc3010&fileType=pdf
Now that you know how to drive the thing, expect it to be very noisy. I have tried this with 240 VAC 50 Hz and the fan buzzes loudly. Switching to a variable transformer made work smoothly and as quiet as ever -maybe more quiet since it was turning slower. Others have had similar experiences with fans and light dimmer type circuit.
shteii01
Joined Feb 19, 2010
4,644
I just looked at ti datasheet from 2009 for MOC3010.
It does not have any explanation about Rin. In their test circuit, Figure 1, they have input signal that is 5 volt pulses. If I remember fight, you also going to use 5 volt pulses for input. I would guess that you don't need Rin resistor because you are using input signal that the part was designed to receive.
Just in case, look at ti website for application notes for this part. Application notes often have a lot of practical info and howto that do not make into datasheet.
#12
Joined Nov 30, 2010
18,224
The emitting LED is rated for 60 ma. From 5V, that needs (5 - 3)/0.06 =33 ohms
but I wouldn't run any LED at its maximum. Try 68 ohms
The thing R2 does is delay the start of the big triac. Try 180 ohms.
tavo91
Joined Jul 11, 2016
15
Also do you guys know any good program that can simulated this i only have Proteus but i am really bad with proteus.
benta
Joined Dec 7, 2015
101
The MOC3010 needs minimum 15 mA through the LED to trigger in all cases. With a maximum LED forward voltage of 1.5 V, you have:
(5 - 1.5 V) / 0.015 A = 233 ohms. Choose 220 ohms as standard value.
For R2, the datasheet suggests 180 ohms, which looks right to me.
Benta.
tavo91
Joined Jul 11, 2016
15
Hey guys I already put the circuit together but I am getting a current of only 3.57 A any advice so it can be 10 A? I put the 180 and 220 Ohms on the resistors
DickCappels
Joined Aug 21, 2008
10,186
Never heard of a triac being less than all the way on or all the way off more longer than a couple of microseconds. If you see 3.57 amps then that is what the load will take with the applied voltage (waveform being taken into account).
When talking about a phase controlled waveforms, the term "Amps" does not contain much information. True RMS, Average, Average represented as RMS...?
