need help to build a 2.5kva ups
Discussion in 'The Projects Forum' started by etiboy, Jun 15, 2011.
  1. etiboy
    Jun 15, 2011
    i want to build a 2.5kva ups,can you help me with hits on cct diagram and others
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    There is not nearly enough information. What frequency and what voltage is the UPS supposed to output? Do you want a pure sine wave output?
    At that level, a 12 volt battery would have to produce 208 amps to drive the inverter at 100% efficiency. A generator may be a better solution.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Actually, the 208A number is without figuring in the efficiency. An 85% efficient inverter would require ~245A current from 12v batteries.
    I used to have a link for a 2KW inverter project, but not on this computer.
  4. #12
    Nov 30, 2010
    16,685
    7,322
    and I used to have a link to a 3000 amp-hour battery...but not on this computer.
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  6. #12
    Nov 30, 2010
    16,685
    7,322
    About 6 of those batteries and this project could work! Now for a 300 amp, 12 volt charger.
  7. etiboy
    Jun 15, 2011
    Thanks,for your hints,the 2.5kva ups i want will give an output of 22ov and 5ohz.can u help with a good cct and details.also will a 12v battery power it for an hr.then how is the transformer going to look like.
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    With almost 300 amps in the primary windings, it's going to be very large. Coupling that much flux will require a large core.
    No. See post #5. That is stretching the batteries quite a bit.
    You also have the problem of all that heat in the circuitry.
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    For an hour's worth of power without killing the battery bank too quickly (lifespan) for 2.5KW output, you would need around 800AH of deep-cycle battery capacity. You could place two 400AH 12v batteries in parallel. Automotive batteries would not last long at all; they must be deep-cycle type batteries.
    The closest thing you will get to a finished circuit for your project from this board is the link I provided. There are a lot of details missing, the project is an old one (14 years old), the transformers will be hard to find, and the software will require modification to generate 50Hz instead of 60Hz, and you will need to change some parts to get 220VAC instead of 120VAC.
