Need help simplifying
Discussion in 'Homework Help' started by minimugy, Mar 30, 2011.
  1. minimugy
    Mar 2, 2011
    7
    Hello! i have a function that i need to simplify to add to a bigger question on my homework.
    the function i have is
    F= A'D + BC'D + AB'D'
    so far i have
    D(A' + BC') + AB'D' (which i simplified this way but im not sure is correct)
    = D(A' + BC') + D'(AB')
    = (D+D')(A' + BC')(AB')
    = (A' + BC')(AB')
    im not sure if it would be (A' +BC') + (AB') or the way i have it. anything helps!
    thanks!
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    This series of equations is seriously wrong. You can't go from
    D(A' + BC') + D'(AB') to (D+D')(A' + BC')(AB').
    I suggest you do a revision on Boolean algebra rules.
    Must you simplify the expression through Boolean identities or can you use a Karnaugh map?
  3. minimugy
    Mar 2, 2011
    7
    i got the function from a k-map. but i am stuck on simplifying it.
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    If you got it from a K-map and you extracted it correctly from it, then there isn't much simplification that can improve the function's length.
  5. johncena
    Member
    Aug 15, 2010
    32
    can we have a look at your output (F) so we can check if you did the k-map correctly..
    if you are 100% sure that your equation is correct, that one was already in simplified state.
