Need help setting up switch on breadboard
Discussion in 'Homework Help' started by droggie, Oct 21, 2012.
  1. droggie
    Oct 21, 2012
    137
    Basically I would like to be able to switch an LED on and off. But for some reason when I push the switch it turns off, I would like to push the switch so it turns on. I cannot upload images so here is an image of the current circuit I have set up. Can some please help me trouble shoot?
    http://postimage.org/image/pxp0ff4nl/
  2. bertus
    Administrator
    Apr 5, 2008
    15,801
    2,387
    Are you aware how a breadboard is connected inside?
    Have a look at the attached PDF.
    For the switch, I have this drawing:
    Bertus
  3. droggie
    Oct 21, 2012
    137
    I am aware of how they work. Am I supposed to connect one positive wire from the power supply or two? Same for the negative? That is where I am confused.
  4. bertus
    Administrator
    Apr 5, 2008
    15,801
    2,387
    Here is the basic schematic on how to connect the led and battery:
    The resistor can be separate or in the led, when it is designed for a special voltage.
    Bertus
  5. droggie
    Oct 21, 2012
    137
    Thank you for your help. I have managed to connect them. I have attached another photo of my breadboard. I am not sure if the resistor is connected properly would you be able to tell me? I do not have a multimeter handy at the moment.
    http://postimage.org/image/aftu4vkbv/
  6. bertus
    Administrator
    Apr 5, 2008
    15,801
    2,387
    Here I have breadboarded the circuit myself:
    I have tested the circuit using a poweradapter.
    Bertus
