Need help selecting components....
Discussion in 'The Projects Forum' started by rye_84, Apr 29, 2009.
  1. rye_84
    Apr 29, 2009
    So I am working with the following component-
    ZXLD1360- http://www.diodes.com/datasheets/ZXLD1360.pdf
    It is a LED constant current driver, but needs 4 more parts to get it up and running. Is there anyone who can help me select the other parts for it. I have done some searching for them, but don't trust myself enough to go through with it.
    I will be using a 24V power supply with 6 Cree 3 watt LEDs in series from the driver. Page 18 of the data sheet talks about the selection of the components. Any help would be greatly appreciated.
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Do you have the datasheet of the leds you are planning to use?
    There are several tables for the "extra" components you need.
    They also depend on the data of the leds.
    Greetings,
    Bertus
  3. rye_84
    Apr 29, 2009
    Here is the data sheet for the LEDs
    http://www.cree.com/products/pdf/XLamp7090XR-E.pdf
    I will be using model # XREWHT-L1-0000-00D01 (cool white) and XREROY-L1-0000-00A01 (royal blue).
    Here is my thought for the capacitor- http://mouser.com/Search/Refine.asp...4294568024+4294438774+4294571674&Ns=Pricing|0
