Need help replacing my AC Motor
Discussion in 'General Electronics Chat' started by retsel25, Aug 2, 2015.
  1. retsel25
    Aug 2, 2015
    Hi there. I'm new here. Trying to replace my failing General Electric Company AC Motor. Been online to get more information about it. The AC Motor being an old, Can't even find anything from it's Model Number. Something that will work is good enough. If Someone can tell where I can find one, or whats compatible, that will be great.
    Here is the failing AC motors Info:
    GE AC Motor
    Mod: 7J404GX4
    HP: 1/2
    RPM: 1725
    V: 115/230
    HZ: 60
    A: 8/4
    PH: 1
    Type: KC
    That's all the information that's on the AC motor.
    Thanks for your help.
  2. MaxHeadRoom
    Jul 18, 2013
    10,865
    2,528
    Dual voltage 4 pole .5hp 1ph induction motor, 8amps 115v - 4 amps 230v.
    You don't necessarily need a dual voltage unless this is important.
    Very common motor.
    Other relevant data, mounting style C face etc.
    Max.
  3. strantor
    Oct 3, 2010
    4,302
    1,989
    (Post a picture )
  4. #12
    Nov 30, 2010
    16,705
    7,358
    Belly band? Butt bolts? U-bracket? Foot plate? What country are you in? USA.
    Failing? Bearings? Those are often replaceable.
