need help pwm circuit
Discussion in 'The Projects Forum' started by jroo, Jul 18, 2008.
  1. jroo
    Jul 18, 2008
    hi looking for a circuit that uses 12v dc frequency variable from 100 to 250khz. it will send a pulse through one side of electrolyzer then send anouther pulse switching the + and - back throught the other side. It is probably very simple but i am a newbie to electronics.
    any help would be greatly appreciated
    thanks jroo
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Here we go again. :rolleyes:
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    :rolleyes:
    Jroo, welcome to All About Circuits. We have a fairly good search feature here: http://forum.allaboutcircuits.com/search.php
    If you use the terms "PWM" and either "hydrogen" or "HHO" you will find some previous threads dealing with this topic.
    Please take all safety precautions when you experiment with electrolysis. Stoichimetric hydrogen explosions can ruin your whole weekend.
  4. jroo
    Jul 18, 2008
    i will check that out thanks for info.
    have you looked at gm water car platform it was featured on top gear. it was a stand alone plat form using salt water through a electrolyzer into a small holding tank through a fuel cell into electric motors cost to build 10 million. but it produced enough power to power the homes on your block.. also no batteries.
    have a look at top gear gm watercar
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Let's try to stay on the topic of electronics, shall we? If you want to discuss other things, please visit our Off Topic forum.
